What power steering belt do I need for a 1992 G2 w/ a JDM B18C swap.
  • What power steering belt do I need for a 1992 G2 w/ a JDM B18C swap.
    I just bought a 1992 Integra GS w/ a JDM B18C swap.
    -- It currently has a power steering pump, I believe from the B18A1 (correct me if I'm wrong if that's not possible, but it has a power steering pump).
    My question is, what model do I need to source a power steering belt for the car because it has a JDM B18C motor in it?
    Will a regular 1992 Integra GS B18A1 belt work with the pump already mounted on the B18C...
    -OR-
    Do I need a power steering belt from a different model year? Such as a 3rd Gen.
    thanks in advance for any advise / help and/or tips.
    You need to run the B18A PS Pump and belt. The B18C comes with a multi rib pulley on the pump. The DA pump uses a "V" belt. You also need to use your B18A crank pulley on the B18C motor to facilitate use of the B18A pump.
    Dan
    92 GS-"R"
    13.9 @ 100mph
    17" street tires
