Alright so I have been looking up all the information on an obd0-obd1 conversion for the past few hours. I pretty much have it all figured out and WAY easier then I thought it was going to be. Problem is the o2 sensor wiring though. I purchased an eBAY jumper harness and as far as I can tell by all the pin outs listed online all the wires are correct.
My issue is I have (A25) IGP2 Power Source, (A23) PG1 Power Ground, (B2) LG2 Logic Ground, (B1) IGP1 Power Ground, (A26) LG1 Logic Ground.
I have no idea what or where these wires need to go.
I have (D14) Prime Heat o2 and (A6) Prime o2 Heat Control so I'm assuming I need to use one of those none used slots for power and ground. My issue is which ones should I use. After hours of searching I can not appear to find a 110% solid and accurate answer to this problem. Thanks for any help or a point in the right direction. I have a headache and going to call it a night and hope tomorrow will give better results.
