Results from leak down test
  • Results from leak down test
    Background:
    LS/VTEC Turbo
    Built bottom end w/ 9:1 pistons
    The car was running a bit rough so I decided to do a compression test, these are the results of the dry and wet tests performed:
    So obviously this doesn't look good, cylinder #1 being the focus of attention.
    I decided not to spend $100 on a leak-down tester so I fashioned up my own using some of the components from my compression tester:
    Results of the leak-down test:
    100 psi, each cylinder set precisely to TDC prior to testing.
    Cylinder #1: 100% leak with all air exiting through the exhaust valves.
    Cylinder #2: 60% leak exiting through exhaust valves.
    Cylinder #3: 80% leak exiting through exhaust valves.
    Cylinder #4: 70% leak exiting through spark plug hole of cylinder #3
    From what I can tell the head needs to come off and the exhaust valves need to be thoroughly inspected. Before I go to those lengths, I figure it can't hurt to ask some of you fine folks for your opinions on the matter.
    Any advice from anyone that has experienced similar circumstances?
    Cheers
    looks like bent or valves that are not seated.. what was done to the head?
      could be that ^^^ or it could be really shitty timing as well
