Will Type r gearing fit in cable transmission
  • Will Type r gearing fit in cable transmission
    I need to know ASAP if Type r gearing will fit in cable transmission and lsd thanks
    Yes, b series hydro gearing will fit into a YS1 cable case - but it will not fit into an S1/Y1/A1/J1 cable case. Also, in order to fit the hydro gears (or the lsd, I forget which is the issue) there is some grinding you need to do on the inside of the case to gain clearance.
    Track Project DB2 #896
    LeMons Project DA9
      Oh ok thank you buddy
        To fit the lsd dif you have to grind down some of the internal casting Web.
