swap problems
  • swap problems
    i did a swap for a friend of mine a 92 ls with b16a1 he was using a 95 gsr ecu and everything was perfect, he had it for a while, we went too the bone yard and found a 93 gsr that was wreck from the back so he bought that ecu know we have a check engine light and will not go past 7500 rmp why is that . i think its reading code 21 but there no such thing
    Why don't you just use the 95 GSR ECU instead if everything was perfect then?
    1992 Integra LS
    JDM B16A
    ITR camshafts
    My Teg
      i thought that 93 was better than 95
        I'm not sure on that. I would think they'd be similar. Anyone here know differences between those two? I'm curious on that too. Fuel curves might be different?
        Anyway, for me, I'm using a P28 (92-95 Civic) ECU reprogrammed to DOHC VTEC specs...GS-R specs I believe. What year, I don't know. It didn't specify when I bought it.
        On the other hand, you can get the V-AFC and set it up how you feel like.
        T
        1992 Integra LS
        JDM B16A
        ITR camshafts
        My Teg
          Code 21 is VTEC solenoid. Double check your wiring.
          The 92-93 GSR ecu is actually better suited to run your B16A. VTEC X-over for a 94+ GSR is just way too soon at 4400rpm and just doesn't seem to run a B16A motor as well as a P61.
          Elmer
