PLX sm-afr help
  • PLX sm-afr help
    I'm following the hondata installation found here. http://www.hondata.com/techplxwiring.html
    Well I finally got hondata s300v3 and I'm trying to install my plx wideband. I grounded it to the thermostat housing and ran the power to the fuse box in the empty ACC slot. The first issue I ran into is that there was no ELD wire at D10 on my harness which I think is weird. So I added the wire to the ecu connector. Anyone with a obd1 have this issue?
    Secondly I decided to see if the gauge would turn on before I tucked all the wires away. But it got no power. I switched power sources with my oil pressure gauge power and the oil pressure gauge had power. Any help would be appreciated.
    figured it out. The audio looking cable wasnt plugged in -_-
