Extreme Surge 92 Integra
  • Extreme Surge 92 Integra
    Cleaned the cold idle valve. Looked for vacuum leaks. Surges from 1000 to 3500 regardless of temp.
    Help please.
    Well hell. Looks like I posted this in the wrong place.
    Sorta makes sense with the day I'm having.
      The only time this has ever happened to me is when a vacuum line popped off. Did you do anything before the problem began that could help provide a clue?
        make sure you don't have air in the coolant if that's not it look into your fast idle valve, fix or replace
          check to make sure you dont have air in coolant/cooling system
          clean out idle air control valve
          clean out fast idle thermo valve
