Extreme Surge 92 Integra
  • Mastermind
    started a topic Extreme Surge 92 Integra
    Cleaned the cold idle valve. Looked for vacuum leaks. Surges from 1000 to 3500 regardless of temp.
    Help please.
  • JayLabaco
    check to make sure you dont have air in coolant/cooling system
    clean out idle air control valve
    clean out fast idle thermo valve
  • WISC DA
    make sure you don't have air in the coolant if that's not it look into your fast idle valve, fix or replace
  • N FUL FX
    The only time this has ever happened to me is when a vacuum line popped off. Did you do anything before the problem began that could help provide a clue?
  • Mastermind
    Well hell. Looks like I posted this in the wrong place.
    Sorta makes sense with the day I'm having.
