Front wheel hub
  • Front wheel hub
    Hi, does anyone know if some other Honda model wheel hub is same as DA? I know that bearings are the same as 3gen (88-91) Prelude, but what about the hub, are they same too?
    you can try getting a hub from a da... those typically work. at least i havent heard of any compatibility issues....
    what problem are you having that you need to know this?
      The problem is - I am from Europe and my DA is only DA in my country..
        Lol, yeah I could see where that could be a problem. Post in wtb and see if someone can ship it to you.
          Yes, thanks, but It would be much easier if someone knew if some other honda model hub is the same (maybe someone tried 3gen prelude one)
            definitely would have helped to lead with that in your first post. in your situation, finding an interchange is actually pretty important. do you have abs? do you need a front or rear?
            for the rear without abs
            http://www.oreillyauto.com/site/c/de...patibilityTab_
            rear with abs
            those 2 links will show you all the interchange vehicles for the rear.
            from what i can find, i dont see any interchange for the front. you may need to take a chance and experiment. i would say try and order one for a civic and see if it matches. theres a good chance it could be the same.
            EDIT:
            spoke too soon
            http://www.bernardiparts.com/Honda-H...0-SF1-980.aspx
            same part, different part number 44600-SF1-980
            says its the same as the 88-89 prelude. not sure how much that helps you
              Thank you, I need front one and yes, we have preludes here, so It helps a lot!
