Track Build - Cindi
  • Picked up yet another car...
    Car by Rob Heckel, on Flickr
    99 GSR, single owner. Fresh-ish paint, done by acura. Head rebuilt at 140k. Currently has 212k. Mint interior, with the exception of a minor bolster tear.
    Current Car
    • That's awesome Rob. I'm usually scared of repaints but if it was done at Acura it was probably a warranty and something that would have cost $5k or more!
      Track Project DB2 #896
      LeMons Project DA9
      • Nothing too new or crazy. Waiting on a harness from CJ's Wiring to show up, now that they have a standalone race version. I decided to hop on that.
        I'm currently in the process of bending brake lines and installing an adjustable proportioning valve. Hoping to get some Antique plates and get this thing to some events soon.
        Current Car
        • Wiring Harness has arrived. Put new (rebuilt) injectors in. Need to finish up the rear lines and pressure test/bleed them. Worked on the gauge panel a little bit. Should be enough to get the car running... 2 flush mount LEDs in the top for CEL and Oil Pressure. 2 little amber ones for the turn signals on the sides of the Tach. The gauge on the right is water temp, left is wideband.
          Current Car
          • That looks great - simple and clean
            LeMons Project DA9
            • Been slacking on updates. Interior is just about buttoned up. Need to install the battery (Odyssey PC-680) and bolt down a couple of grounds, then we shall see how my Electrical Engineering 101 project went...
              Interior bits
              Interior bits
              Interior bits
              Interior bits
              Interior bits
              Current Car
              • Coming along! That camo ain't my style but I like where you're going nonetheless. Love the plug for the ignition switch key cylinder Speaking of which I swapped my ignition switch out this weekend and had my own wiring project (swapping the switch is easy but when your alarm is hacked into all that wiring it becomes less easy, much less easy if you're me and always trying to make things more tidy with less cuts/splices). That project left me REALLY wanting to remove my dash and rewire everything under there. Or maybe get more crazy? I'd been wanting to keep everything OEM in terms of wiring except just stripped down but man some of that wiring is way too complex for no good reason. Tempting to do as you did and just start from scratch.
                You probably already know this... but just in case not, be sure to keep a tender on that PC680, those things go dead super quick if you're not driving the car regularly.
                LeMons Project DA9
                • Yeah, the camo is more or less to hide imperfections from my impatience. I was wondering if anyone would notice that plug! Just popped a random grommet in and it fit. I had to go out and buy the ignition switch wiring from another junkyard car because mine was so chopped up from the alarm. (back before I took on this project) Obviously, you've seen the duration on this project... think long and hard about rewiring. I wish I would've never done it. I did about 90% of the car with the fancy mesh loom, and for the final bits, I just got impatient and used the Tesa tape to whip things up quickly. Under the dash, no one will see it and the time spent fishing into the mesh loom just wasn't worth it for me. I wish I wouldn't have wasted so much time with that. tons of zip ties and Tesa tape. That's my new motto.
                  Current Car
                  • Yeah, I hear ya there. It's my OCD brain that drives this stuff but then I forget about it once it's all buttoned up. I just ran into an issue during my install (user error) and troubleshooting was a huge pain - mainly because the stock wiring is a little confusing. Just seems that troubleshooting could be easier if I re-did everything. But I suppose I might then also need to write my own service manual, lol.
                    LeMons Project DA9
                    • lol yes. My service manual is on a bunch of notebook and computer paper. And the electrical schematics? Well. They make sense to me. Maybe I
                      Current Car
