the subtle track car project.
  • the subtle track car project.
    I guess this is a good place to share the progress in my integra. I bought the car in orlando 2 years ago for dirt cheap and drove it back to michigan. It was missing pretty much the entire interior and had a skunk2 mega power exhaust, blown struts with upside down skunk2 springs lol. But the b20 was very healthy.
    The car now looks very stock with no wing, roll bar or front diffusor yet, but they are on the way.
    I do autoX, HPDE and time attack with this car out in the midwest.
    Suspension:
    I've went through a few coilover systems:
    F&F: not good blew with in months and my car is not slammed. Also the travel is not great.
    P.I.C coilovers 10k F 6k R: these were great but after many years of abuse the rear left blew and I figured its a good time to try something new.
    Now I have Koni yellows GC F:550lb R:450 with gc extended top hats
    -ASR 24mm rear sway bar and brace (makes the rear end a little tail happy)
    skunk2 front & rear camber kit. The rear bushings are shot so they need to be replaced. I'll probably go with SPC aka doorman since they are fairly strong and cheap.
    -Function7 rear lower control arms
    -innovative front traction bar that still needs to be installed.
    -no name rear strut bar
    -hard race rear camber kit
    -hard race rear trailing arm bushings
    Tires
    -Front: 205/50/15 Dunlop Z2 star specs
    -Rear: 195/50/15 Dunlop Z2 star specs
    Wheels:
    -Enkei j-speeds 3 15x7 +38mm
    -ARP extended studs
    brakes
    -hawk HP+
    -centric cryo rotors
    -ATE yellow fluid
    Engine:
    -jdm B18c1
    -ctr pully
    -science of speed LMAs
    -supertech flat face race valves
    -Itr valvesprings
    -CTR Cams
    -toda cam gears
    -RC310cc injectors
    -Skunk2 intake manifold and 70mm throttle body port matched
    -hondata thermal gaskets
    -blox v stack and filter
    -toda rep header
    -moroso oil pan
    Exhaust:
    -vibrant ultra-quiet resonator at the testpipe, skunk2 mid pipe paired OG vibrant axle back (sound like a motor bike lol )
    Drivetrain:
    92-93 gsr ys1
    competition stage 2 clutch and lighten flywheel
    innovative shift linkage
    Fastline shifter
    Engine management:
    Hondata s300v3
    electronics:
    -plx wideband with joe's dash gauge pod
    -tanabe oil pressure gauge.
    Right now I'm assembling the head. The machine shop did a great job cleaning head
    Auto machine for those in the chicago area.
    I'll post pics as I go along assembling and pulling out the p30 piston gsr block.
    Lookin good!
      Awesome! Keep us posted
        I like it! Thanks for sharing your experience with coilovers as well
        Current Car
          mint! very clean
            pulled the cams and found that the exhaust skunk2 stage 1 cam ate the rockers. So I pulled the head to do some searching. I found 2 broken valve guides and some head damage -_-
              awesome. i'm from Michigan too man. it would be awesome to have a meet one of these days out here when my car gets done
                Nice ride man! I love how clean and simple the exterior is, nicely done. For the build, I can relate to the direction that you're going with the build. I also tried a few different setups before I was impressed and settled on the koni/GC setup. Keep us posted on progress.
                  I live in the chicago burbs now. But i'm always at ginferman race way in south haven
                    out with this trash.
                    fF type 1s were in for maybe 9 months and hit the track maybe 3 times and died on me.
                    • #11
                      some suspension upgrades.
                      innovative traction bar. The only traction bar that actually does not buckle under track conditions.
                      • #12
                        HEAD Work. Got the new head cleaned and had the valve seats cut.
                        Speed of Science LMAS
                        • #13
                          Got the head on the block
                          70mm blox tb and port matched with skunk2 mani
                          Moroso pan : ). So no oil starvation on track like I did a few yrs ago lol
                          • #14
                            Got the motor in and had to do some wiring for the oil pressure gauge.
                            I also put rtv in the moroso pan oil plug threads so they won't leak.
                            • #15
                              Out with the old beat up skunk2 rear camber arms. Replaced with hard race camber arms.
                              Also replaced the torn up rear trailing arm bushings with hard race bushings. One busing was actually broken all the way and just dangling.
