Results 1 to 8 of 8
Thread: How do I replace the rear motor mount?
  1. #1
    Hey all. I have searched for motor mounts and i see that everyone says that the rear mount is a pain but then no one said how they replaced it. I can see that the rubber is gone and i get really bad vibrations so I need to replace mine but looking at it, it seems impossible to get to the inside bolt. Cant get it from the top of the engine or the bottom. It also looks as though the whole steering assembly is in the way. I wouldnt want to remove that if at all possible. If someone has a quick how to get that thing replaced I would greatly appreciate it. Thanks a bunch.
  2. #2
    Join Date
    18 Apr 2002
    Atlanta, GA
    i'd take it to a dealer/mechanic to do.........don't know of anyone who has done it themselves without having something else major done, like engine replacement
  3. #3
    remove the intake manifold support bracket. That will make your life so much easier.
  4. #4
    Join Date
    09 Sep 2003
    Rapid City, SD
    that rear motor mount is a bitch, unless you're doing something else major like dawn said.
  5. #5
    Join Date
    08 Sep 2003
    Metairie, La
    just some info my local mechanic told me
    to replace 1 mount.. any of them.. is 1.2hours.. to replace all 4.. is 2hours.. im waiting untill i get all 4 mounts to get them installed
    im pretty sure those times are alldata
  6. #6
    Join Date
    30 Oct 2001
    Quebec, Canada
    Like everyone said, the rear mount is a bitch to replace... can't you find something major to do at the same time? :p
    90 Integra GS in Rio Red --- Not Stock!
    90 Integra RS in Blade Silver Metallic. --- Gone to Tegs heaven.
    90 Integra LS in Frost White --- GF's ride.
    96 Integra RS in Cypress Green Pearl --- Sold
    09 Mitsubishi Lancer GTS in Graphite Gray --- Traded
    10 Mitsubishi Lancer Ralliart in Wicked White --- Traded
    11 Mitsubishi Lancer Evolution in Wicked White --- Daily Driver
  7. #7
    OK so its a bitch. I got that much...Anyone have any ideas?
  8. #8
    Join Date
    28 Dec 2004
    Vancouver Washington
    You'll need to unbolt it by running several extensions down along the firewall, going between the motor mount and the firewall to get the bolt there. (you'll probably find out you won't actually be able to snap the extension into the socket) Also, take the front mount and passenger side mount off, and put a jack to support it under the transmission. Then, there's also a bracket that holds the rear motor mount to the engine. You'll need to unbolt it from the engine, and then you'll find that you need to jack the engine up a few inches to actually get the motor mount out.
    You will probably need someone to help you do this, unless you want it to take twice as long.
    good luck
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
