+ Reply to Thread
Results 1 to 7 of 7
Thread: Precision Injectors
  1. #1
    k9n
    Precision Injectors
    Hey guys I am almost done with my turbo kit and ran into a problem with my injectors. I have precision 440's and they are too big to fit into the injector holes (don't know the exact name). Anyways, is anyone running precisions? I would like to keep my injectors so i could install them tommorow so if there is a trick I am missing, let me know.
  2. #2
    Join Date
    28 Oct 2004
    Location
    seneca, south carolina
    you could do the trick that is used with the dsm 450's, the stiffer injector oring (assuming this is what you cant get it to go into) needs to be bored out a bit to fit the injector, use a dremel and just do a little bit at a time and keep checking it to ensure a snug fit
  3. #3
    Join Date
    28 Oct 2004
    Location
    heres a link on how to do it, scroll down a bit to find out how http://www.hstuners.com/forums/showt...threadid=11436
  4. #4
    k9n
    thanks for the effort, but the problem is that the metal tip on the precision won't fit through the metal hole in the engine for the injectors....
  5. #5
    k9n
    Would there be any harm in opening up the holes on my intake manifold with a dremel to accomodate the injectors? Then if i wanted to get back to stock injectors, the seals would still do their job, correct?
  6. #6
    Join Date
    29 Apr 2004
    Location
    new jersey
    my precision 780's fit perfect no mods. those for hondas?
  7. #7
    k9n
    yeah, they were used on a 00 si....
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
