Page 2 of 2 FirstFirst 1 2
Results 21 to 32 of 32
Thread: Cold Air vs. Short Ram
  1. #21
    Join Date
    13 Feb 2002
    Location
    Newton Falls, OH
    I went from the no resonator, no bottom side of air box thing to an AEM CAI and there was a noticeable difference. What I want in the end is a short ram in an air box. So you get the same cold air from a CAI, less piping length for quicker response, and no water risk(which i'm not really worried about eevn when it's raining). Boy do they look cool!
    The only real difference between a AEM CAI and an ebay CAI is the filter(which is why I bought the AEM), the carb sticker (which I don't care about), and the fact that its light (not made of steel). I am also sure the AEM will fit where as the ebay stuff is often questionable.
  2. #22
    integ115
    The picture above is a short ram intake.
  3. #23
    thunder_mike
    Will I notice a performance increase going to a ram intake (From ebay) from a stock air box without resinator. about how much HP? and what would I notice, THEN, what about going from a eam air to a CAI? And noticeable difference there?
    Im kinda of leaning towrds ram air becasue I dont want any problems with hydro lock..
    Mike
  4. #24
    DOHCtor
    What I'm doin is sorta like this. I have a short ram intake because from what I understand, it's better at producing low end power than a CAI. It's just a plain old aluminum intake tube with a Blitz SUS filter on it. I moved my battery to the back so right now I'm working on building a heat shield out of ABS plastic and some thermal lining from thermotec. I removed my resonator and cut the plastic away under the mud guard and covered the hole with some mesh. I am still trying to decide whether or not to run a tube from the hole to the resonator hole, or do the extension like in the teg tips section. I've even thought about cutting a hole in my 93 bumper and installing a tube from there to the resonator hole. but I thought I'd save that until I go full-race with it.
  5. #25
    Integra Style
    You should try the ram air extension in teg tips, it helped me alot. iI have an HKS filter with the original plastic arm thingamajig and i felt a significant increase of power.
  6. #26
    Bombtrack
    saw this on a site...
    For every 11 degrees F that you lower the intake air temperature, you're reward with approximately a 1-percent horsepower increase.
    So if your underhood temperatures are in the 165 degree F range and it's 80 degrees F outside, you'll get a 7.7 percent increase by ducting outside cool air to the intake.
  7. #27
    G2IC Commander
    Join Date
    06 Nov 2001
    Location
    orange county, California
    in case the pic gets lost, its the sticker on the AEM intake
    CAUTION! - If you anticipate traversing deep water (over 16", less if vehicle has been altered) remove the AEM Cold Air extension and replace it with the original equipment air intake system
    *archivethis*
    autozone online repair manual
    http://www.autozone.com/addVehicleId...leSelected.htm
    supplement with haynes manual from pep boys (<$15). includes vital troubleshooting and maintenence schedules.
    pics of all gsr rims
    b-series dynos
  8. #28
    dattegbol
    buy a ebay cai and cut it for a short ram and buy a silicone sleeve and figure out which one you want to use
  9. #29
    Join Date
    13 Nov 2001
    Location
    chicago illinois
    i was reading on another board that the only real difference you feel with AEM CAI is the power spike. thats all. the AEM does provide other power but thats the most you'll see. and short rams are good for very high revving engines. i heard of many type r ownders ditching their AEM CAI for a nicely made short ram intake. if i find that discussion ill link you guys. it was very in depth. something im not too good at
  10. #30
    Integra_Pilot's Avatar
    Join Date
    29 Oct 2001
    Location
    'The Boonies'
    Daym, who dug this thread up?
    I think I posted here back in November....hahaha.
    - Darren
    1990 'Whitey' RS R.I.P.
    1991 GS in the werks!!
    Praise the Lowered
  11. #31
    1Bean1
    Maybe it was this link, which I ran into earlier when I did a google search on aem integra intake filters
    http://www.hondalife.com/articles/intaketech.htm
    It's a good read with some dyno tests, which aren't at all definitive but interesting none the less (two different cars were compared, the cold air was not simulated on the dyno, etc., but there is one dyno test between equal diameter intakes on the same car).
  12. #32
    G2IC Commander
    Join Date
    06 Nov 2001
    Location
    i found that the underhood temps in the stock location are the same when you are moving, otherwise when at a stop it can rise 30-40F, then lowers back to ambient once you're moving again. so focus should still remain on intake diameter and length.
    b-series dynos
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
