Results 1 to 5 of 5
Thread: tire unevenly worn down to steel belt
  1. #1
    Join Date
    12 Jan 2008
    Location
    Eureka, Calif. USA
    I noticed a few days ago that the inside edge of my left front tire was massively worn down. So worn down, in fact, that frayed steel wires were sticking out. Yeah, no kidding. It was kind of alarming since I was 150 miles from home visiting friends for 4th of July.
    I swapped it to the back of the car before driving home, and luckily it didn't blow on the way.
    Any ideas on what could be causing this? I sort of need new tires anyway (and an alignment, of course) but I'd like to understand what the problem might be before dealing with a repair shop.
    The car, by the way, is completely stock (steel wheels and everything), not lowered or modified in any way, and the tires are rather ordinary Continentals that I rotated around a few times since I got the tires and an alignment 43,000 miles ago.
  2. #2
    Join Date
    05 Jan 2004
    Location
    Denver Colorado
    I would check out the upper control arm bushings and ball joints, as well as the lower ball joints and tie rods. Making sure the boots and bushings aren't torn
  3. #3
    Join Date
    07 Dec 2005
    Location
    Toronto, Ontario, Canada
    If you're due for an alignment anyway, why not do it now? The alignment guys normally would inspect your suspension to check if everything is in order before doing the alignment job, and would tell you if anything is out of whack so it can be fixed before a proper alignment job can be done. We can all just speculate as to what's wrong with your suspension, so why not let the alignment guys get their hands dirty and tell you what's wrong with your suspension.
  4. #4
    Join Date
    17 Jul 2006
    Location
    Seattle
    More then likely your toe is out of spec. Either came loose or you are not telling us everything in regards to anything that may have happened to the vehicle since the last alignment.
  5. #5
    Join Date
    12 Jan 2008
    Location
    Eureka, Calif. USA
    Thanks for the replies. Good to know about the toe-in issue. Nothing significant has happened to the car since the last alignment (haven't hit any curbs or giant chuck-holes, etc). I try to be real gentle with the car and drive like a little old lady most of the time. When I have a minute I'll jack up that corner of the car and do the standard tests to see if the tie-rod or ball joints are loose. I'd just like to know what's wrong before I bring it in to the shop so they don't try to scam me.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
