Results 1 to 13 of 13
Thread: Car moves forward in Neutral !?!?
  1. #1
    Join Date
    10 Jul 2008
    Location
    Torrance California, USA
    When I let the clutch out and the car is in neutral it moves forward (on flat ground with the parking brake off). It is almost like putting it in first gear... but it definitely is in neutral. If I depress the clutch the movement stops. I can also hold the car back with my foot out the door on the ground too. This only happens when cold.
    It is also difficult to get into 2nd gear when cold (you have to move the shifter quickly from 1st to 2nd or it resists going into 2nd.. but it does not feel like grinding or make any grinding noises... the hotter the car get the less this is a problem though.. and it shifts normally when hot)
    The car has a new excedy clutch, lightened flywheel, syncromesh friction modified fluid.
    Is the forward movement while cold and in neutral normal?
  2. #2
    Join Date
    13 May 2008
    Location
    Whitewater WI
    6spd FTW?
  3. #3
    Join Date
    07 Dec 2005
    Location
    boosting around the 303
    Quote Originally Posted by JAMAICAN B18 View Post
    6spd FTW?
    OP, this is deffinatly not normal and wish I could help. good luck
  4. #4
    Join Date
    04 Mar 2008
    Location
    St. Johns NL
    kinda sounds like the clutch i not disengaging all the way or something. id try adjusting the cable first only cuz its the easiest thing to do. weird that your not hearing any chattering though or noises at all. Check trans fluid level too?
  5. #5
    Join Date
    10 Jul 2008
    Location
    clutch cable is new, and adjusting it has not made a difference (it actually shifts very nicely when warm, good pedal feel and proper height). I think I am going to drain out the syncromesh and go with the regular motor oil and see what happens.
  6. #6
    Join Date
    04 Mar 2008
    Location
    St. Johns NL
    I cant imagine that would do anything at all except cost you money but Im certainly no expert. Keep us posted...
  7. #7
    Join Date
    07 Apr 2009
    Location
    bayarea, CA
    this is
  8. #8
    Join Date
    10 Jun 2009
    Location
    rogers arkansas usa
    very wierd cause if it's in neutral there's no connection/engagement between the engine and axles, whether the clutch is engaged, partially engaged, or disengaged it can't turn the axles. almost seems like something in the tranny is constantly binding, or similar, in order to keep the gears engaged
    hmmmm......
  9. #9
    Join Date
    23 Jan 2010
    Location
    San Jose, CA
    what engine and transmission combo do you have, did you buy a brand new clutch for the same engine?
  10. #10
    Join Date
    29 Jul 2006
    Location
    Langley, BC, CANADA
    I had a similar problem a while back. Turns out the pilot bearing exploded due to the flywheel not being machined to spec.
  11. #11
    Join Date
    13 Feb 2008
    Location
    Union City, Ohio
    Quote Originally Posted by dew1989 View Post
    Ouch
    The first thing that came to mind was the shifter bushings. $20 for urethane ones. Something worth checking out before digging into the pilot bearing.
  12. #12
    Join Date
    07 Apr 2009
    Location
    bayarea, CA
    Quote Originally Posted by therealkroysc View Post
    Ouch
    why does it have to do with bushing , it doesnt make any sense.
  13. #13
    Join Date
    10 Nov 2009
    Location
    Ireland
    It dosent mean anything is wrong with your car, any car and move forward while in neutral, and if the bearings were gone in the gearbox it would be making some weird sounds, apply the hand brake.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
