+ Reply to Thread
Results 1 to 5 of 5
Thread: ECU codes correction
  1. #1
    G2IC Commander
    Join Date
    06 Nov 2001
    Location
    orange county, California
    "6 - Crank Angle" is incorrect. 6 is ECT: engine coolant temperature. 4 is Crankshaft Position sensor (CKP).
    here is a correct list:
    Honda 4-Cylinder ECU Troublecodes:
    0: ECU
    check the ECU electrical connector. if no loose connectors are found, have the ECU diagnosed by a dealer service department or other qualified repair shop.
    1: Oxygen Sensor "A" (Primary)
    defective circuit or unplugged / defective sensor
    2: Oxygen Sensor "B"
    3: MAP Sensor (Manifold Absolute Pressure)
    4: CKP Sensor (Crankshaft Position Sensor)
    5: MAP Sensor (Manifold Absolute Pressure)
    mechanical problem / disconnected piping
    6: ECT Sensor (Engine Coolant Temperature)
    7: TPS (Throttle Position Sensor)
    8: TDC Sensor (Top Dead Center)
    9: CYP Sensor (Cylinder #1 Position)
    10: IAT Sensor (Intake Air Temperature)
    12: EGR Lift Sensor (Exhaust Gas Recirculation)
    check the hoses, the EGR valve lift sensor and the System EGR valve.
    13: BARO Sensor (Atmospheric Pressure)
    14: IAC Valve (Idle Air Control)
    15: Ignition Output Signal
    missing or defective ignition output signal
    16: Fuel Injector System
    defective circuit or unplugged / defective fuel injector
    17: VSS (Vehicle Speed Sensor)
    19: Automatic Transmission Lock Up Control Solenoid Valve
    defective circuit or unplugged / defective solenoid valve
    20: Electrical Load Detector
    21: VTEC Solenoid Valve
    22: VTEC Oil Pressure Switch
    defective circuit or unplugged / defective oil pressure switch
    23: KS (Knock Sensor)
    30: Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
    31: Automatic Transmission Signal "B"
    41: Primary Oxygen Sensor - Heater
    check the heater for the proper voltage signal.
    43: Fuel Supply System
    check the fuel pressure, fuel pressure regulator. check the oxygen sensor. also, check for vacuum leaks.
    45: System Too Lean or Too Rich
    malfunction in the fuel monitoring systems
    48: LAF Sensor (Lean Air Fuel)
    54: CKF Sensor (Crankshaft Speed Fluctuation)
    58: TDC Sensor 2 (Top Dead Center)
    61: Oxygen Sensor, Heated - Sensor 1 (Primary)
    high voltage, low voltage, or slow response
    63: Oxygen Sensor, Heated - Sensor 2 (Secondary)
    65: Oxygen Sensor Heater (Secondary)
    malfunctioning or defective oxygen sensor heater
    67: Catalyst system Efficiency Below Threshold
    malfunctioning or defective catalyst system
    70: Automatic Transmission
    malfunction with the automatic transmission controls
    71: Cylinder 1 Misfire or a Random Misfire
    a condition is present that is creating a cylinder misfire
    72: Cylinder 2 Misfire or a Random Misfire
    73: Cylinder 3 Misfire or a Random Misfire
    74: Cylinder 4 Misfire or a Random Misfire
    7:5 Cylinder 5 Misfire or a Random Misfire
    76: Cylinder 6 Misfire or a Random Misfire
    80: Exhaust Gas Recirculation
    insufficient flow detected
    86: ECT Sensor (Engine Coolant Temperature)
    circuit range / performance problem
    90: Evaporative Emission Control System
    leak detected in the fuel tank area
    91: Fuel Tank Pressure Sensor
    low input
    92: Evaporative Emission Control System
    insufficient purge flow
    last revised 08/15/03. codes 0-43 verified via haynes manual for 90-93 integra. xdeep0@yahoo.com
    autozone online repair manual
    http://www.autozone.com/addVehicleId...leSelected.htm
    supplement with haynes manual from pep boys (<$15). includes vital troubleshooting and maintenence schedules.
    pics of all gsr rims
    b-series dynos
  2. #2
    raven
    i have a ck4 on the ecu codes but the car runs great
    it all started out after i put on a aftermarket in take can some one please help me clear it
  3. #3
    Join Date
    17 Jul 2003
    Location
    Gilbert, Arizona
    when do you get the codes? i know that you watch the ecu under the passenger foot area, but is it when you start the car? my car is running on 3 cylinders and has an idle problem, and im pretty sure ill get a code, but i dont know how to get it
  4. #4
    Join Date
    17 Jul 2003
    Location
    Gilbert, Arizona
    nevermind, i just read the teg tips
  5. #5
    gen2integra83
    nice set of codes..now i have some were to go to when i get a CEL
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
