Parts list recommendation during clutch replacement
  • Parts list recommendation during clutch replacement
    Hi all,
    I am taking advantage of the winter break to refresh numerous aspects of my track car. I am planning on the following:
    -Header
    -Shift linkage and bushings
    -Install refreshed transmission, new clutch, & flywheel
    Is there a recommended parts list of wear items to replace while in there doing a tranny/flywheel/clutch?
    getting a clutch kit? if not, replace throwout bearing and pilot bearing. might as well change the crankshaft oil seal.
      While your in there...........
      The clutch cable
      The clutch spring
      Pilot and throw out bearing
      Rear main seal
      Transmission oil
      All i can think of.
        Axle seals?
          So far i am planning on:
          - Clutch
          - Flywheel
          - Pressure plate
          - Clutch cable
          - TO bearing
          - Pilot bearing
          - Axle seals
          - Release fork spring
          - Rear main seal
          What fluid is recommended?
            I'd stick to Honda MTF. If it grinds, try a reputable syncromesh.
            When that transmission was new, simply 10w30 motor oil was the recommendation.
              i stopped using honda MTF and went with amsoil syncromesh its good stuff and my tranny is soo smooth
