how to remove shifter slop?
  • how to remove shifter slop?
    how do you remove shifter slop? i currently have billet shifter bushings (both front and rear), innovative shift linkage and ktuned short shifter. should i possibly switch to polyurethane shifter bushings? tighten u joint possibly?
    Do you have the aptly named "bitch pin" (round spring that you have to punch in and out) that goes from the shift rod and holds it to the transmission or did you try to replace that with just a bolt?
