How can i confirm LSD in my tranny?
  • Guest's Avatar
    Guest replied
    awesome , thanks for the replies!
  • kyle10182
    got this picture today of a NON-LSD S1 tranny that came from a 90 integra
    see the bar going through the middle? that means no lsd.
  • kyle10182
    do you understand what a differential is?
  • kyle10182
    motors? or transmissions? so yes.
    Originally posted by kyle10182
    i dont think any honda motor came with lsd....ever.
  • Guest's Avatar
    Guest replied
    some honda motors came with factory lsd. xsi integra came as an option. usdm ITR. a bunch more. so yes. some honda motors came with lsd
  • kyle10182
    Originally posted by grltnr
    i bought a tranny and the seller says that it is a b18a 1990 LSD tranny.
    awww sheeeit. sounds fishy.
    look inside the hole that the axles go into. OEM LSD looks like this:
    Non LSD will have a vertical bar going through that hole.
    Originally posted by brian349
    no b18a motor came with a factory LSD. either he lied to you. or he had one installed.
  • Guest's Avatar
    Guest replied
  • b18/16
    like 924dr said if you look it the axle hole you should see right through it. if is not a lsd you will see a metal tub or something like it in the middle.
  • Guest's Avatar
    Guest replied
    On factory honda LSD it will have "LSD" stamped in black on the trans. Just my .02!!
  • XsiJDMteg
    Do what Andy said...Jack the car up (always use jack stands). Then spin the driver's side wheel and if the other one spins then it has LSD.
  • 924dr
    look at the tranny, where the axles goes. you should be able to see all the way to the other side. if you cant see to the other side, then its not lsd
  • Andy
    I've never had a FWD with a LSD but I know on a RWD if it has a open differential and you turn 1 of the drive wheels 1 way the other one will turn the opposite.
  • Guest's Avatar
    Guest started a topic How can i confirm LSD in my tranny?
    how can i confirm?
    does anyone have pics of what the axle holes should look like?
