How do i remove the VSS (Vehicle Speed sensor)
  • Wraith
    Just be vary careful with the VSS hold down & bolt. These are known to be kind of fragile.
    Just some things to think about in case you haven't already. It is recommended to have your flywheel resurfaced before installing a new clutch. Clean it once it is back in with brake clean to remove dirt, etc....
    There are also a couple over-looked parts that are fairly cheap, and a good idea to replace while you are in there. IE - clutch fork return spring, and pilot bearing. Neither of these come with "standard" clutch kits so get them from Acura or an online order site.
  • Speeddaddy
    remove the screw that holds it to the trans, pull it out. finish rest of work to change clutch.
  • 90DA-Pedro
    started a topic How do i remove the VSS (Vehicle Speed sensor)
    Just as it says,
    I swapped in a B16A into my da.
    Now I need a clutch so im droppin the tranny...
    Did the swap, but I havent ever done a clutch job.
    So this is my question thrread...
    its still in the car also...
    Following the haynes manual...
    First question....
    Without removing the hoses etc.....
    I pulled the VSS line out but I need the assembly out of the tranny....
    Thanks!
