This one is #3 1990 da.
    Just bought this one yesterday. 90 LS b18b
    Main things that  need attention first.  Needs to be raised up a bit as the body scrapes the tires. On bumps etc.  I noticed.  The clutch needs attention. Either its way out of adjustment or the cable or the clutch assembly need replaced.  Those are first.
      some more pics of car.
      pic of interior is after i installed extra one i had
      i also had to locate an air intake as there wasnt one on it at purchase
        I would definitely raise it. When a car is that low the upper control arms usually hit the unit body as well, not good. Also the exhaust manifold is going to bottom out all the time on the pavement.
          I agree. This chassis naturally doesn't want to be slammed. I learned this the hard way! But anyways, great looking DA! Do you plan on painting the car so the panels match?
            replaced the steering wheel with one i had . vacuumed and cleaned up .
              Where
                #8
                Looks like a good start. I love the look of a lowered DA, but like everyone is saying, it comes with a lot of clearance problems.
                  #9
                  im having issues again trying to upload pics.
                  last time it was some error about reaching my file size limit .
                  now its just a general error.
                  thanks everyone for the replies.
                  ill try again today later. on
                    #10
                    Thank you for providing useful information, which is very helpful to me.
                    https://www.allicdata.com
                      #11
                      Oh. Big update. Just recently in june 2019. I was determined to be disabled due substantial to mental health issues. Which i was .awarded a decent back payment amount. Soooo. Car parts. Lol. As the list of parts bought to be installed. .
                      Yonaka full coil over suspension setup
                      Ultra race front strut brace (one piece welded design)
                      Dc sports rear. Strut brace ( one piece welded design)
                      ASR rear 24mm swaybar with reinforcement plate and spherical bushing endlinks
                      Skunk2 front adjustable ball joint upper lca's
                      Energy suspension shifter and steering rack bushings
                      Comp clutch lightened flywheel 12lb (iirc)
                      Comp clutch 1.5 clutch kit
                      Neptune rtp license
                      Lc2 wideband band bosch o2 sensor
                      Custom made obd1 engine harness for p&h injector use, 4 wire o2, obd1 distributor, obd1 ecu.
                      Obd1 distributor
                      (Purchased these next couple items in case i needed them wasnt sure if i would. I intended on purchasing. A set of remanned OEM prelude vtec 345cc injectors but trying to source a set that i knew were guaranteed to be the real deal was a headache. So...
                      Rc brand 370cc p&h injectors
                      Aem high flow fuel rail. With braided fuel line
                      liquid filled mechanical fuel pressure guage
                      Mounted on rail
                      Sourced locally. Its used but in excellent shape.
                      F/R Power stop rotors and pads
                      Moog premium grade (designated with part number starting with "k")
                      Outer/Inner tie rods
                      and
                      Lower ball joints
                      Momo steering wheel hub adaptor
                      Momo 330mm steering wheel
                      And a momo horn button with honda emblem
                      I maybe forgetting a few things.
