BLKACK1's Build Thread
    HAHA, thats perfect timing from my last post
    Got the timing belt all tensioned and the oil pan finished up last night. gonna finish up with the flywheel cover plate and the down pipe. after that all I need is a new wg gasket, do a valve adjustment(going to tighten up the clearance to see If i can get that valve train to quite up a little bit), get the vc back on and prime the oil pump before I actually start it up.
      well we look forward to see it run then yea i saw my post and you wrote on it too lol.
        Um where are the updates? Slacking man
          ^I agree. Slacker.
            Slacking, in this thread? Nowai!
            I hope to read good news in the coming few days sir! No upgraded Toda oil pump gears this time around?
                well at least it didn't explode like mine did. hope it all works out!
                  WHOAAAA!! who said any thing about slacking in this build... Ive just been slacking on updates
                  its late, and work at 6 in the morning is not far away so im gonna give you the cliffnotes of the last 2 months.
                  fixed oil pump/seal didnt seat right
                  drove to emission/ wouldnt do. small oil leak and I quote"A Fraction of an inch too low" WTF really!!!
                  replace main seal/ striped TB tension...
                  Motor is currently on the floor of my garage awaiting 2 time serts( finding time when Im not physicly exhausted has been the only reason thats not done yet..)
                  Unified--- nahhh, no toda. just a good old OEM.
                  knock on wood. Im still not out of those woods yet so dont go jinxing it
                    on with the pics
                      Well, glad that you have been busy!
                      Looking good sir.
                        peekaboo
                          Looking good sir.
                          Thank you, Thank you.
                          Originally posted by tegboi View Post
                          peekaboo
                          Kevin, what up brotha. havent seen you around in a while. I hope all is well
                          Finaly getting a day off after 2 months of strait work. plan is to get started on the timeserts tomorrow.
                            Bullshit. Plan is to finish the timecerts and install motor. Yup.
                              LOL so close....
                              Got new updates, most good, some bad...
                              Got both time serts in..
                              started with the half shaft. the striped out threads
                              My savior!
                              Marking the depth measurement to ensure I dont go to deep.
                              Old thread drilled out
                              Taping block for insert.
                              threaded hole
                              insert in place and finished up
                              On to the timing belt. to busy concentrating on not messing it up but managed to snap a couple while I was using the insert tool and end result.
                              Time belt went on without incident, and motor is back in the car
                              got the entire back side collant, electronics, cables and hoses hooked up. went to grab the radiator for installation and I noticed a little blue residue at the base and decided to have it pressure tested. Wish I hadnt done that... turns out there are more then a couple small holes and It appears as if the core is rotted/ing out...
                              I decided being this bad boy has lasted me well over 10 year between 2 cars, countless times of being in and out of the car, daily driving and all out track days.. It was time for a new one. IMO, it wasnt worth the money too repair with such a uncertain future. new radiator should e here Tuesday along with another 6an bung. hope to have it welded, back to me and installed along with every thing else and running in 2 Fridays. Shortly there after gonna hit the dyno for a finshed tune..
                              updates to follow soon
                                Hell yes!
                                Those time-serts can be tricky, but it looks like you got it handled. Top notch work sir!
                                Out of curiousty, what radiator did you end up going with?
